Timing to Raise Feeder Tray
You can select the timing for raising the feeder tray when scanning originals using functions such as Scan and Store, and Copy.
For information on the optional products required to use this function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Scan Settings].
Press [Timing to Raise Feeder Tray].
4.
Select [When Start Is Pressed] or [When Panel Is Touched] → press [OK].
