Setting the Image Priority
This mode enables you to set the machine to automatically select whether the print quality of your original has priority or the print quality of the stored image form has priority. You can also select these settings manually.
Press [Function Settings] → [Common] → [Print Settings].
Press [Superimpose Image Quality Priority].
4.
Specify the following setting → press [OK].
Details of each item are shown below.
[Auto]:
The machine automatically selects the print quality of the original and image form.
[Original Priority]:
Priority is given to the print quality of the original image.
[Form Priority]:
Priority is given to the print quality of the image form.
» Settings/Registration » Function Settings » Common » Print Settings » Setting the Image Priority
08JK-09E
