Enabling Timeout for Suspended Jobs
You can set the suspension time for jobs suspended because the designated paper was not available when the job was issued. After the suspension time elapses, the next job is automatically processed.
Press [Function Settings] → [Common] → [Paper Feed Settings].
Press [Suspended Job Timeout].
4.
Select [On].
Select [Off] if you do not want to enable the timeout.
5.
Press [-] or [+] to set the time until suspended jobs timeout, and the next job is automatically processed → press [OK].
If a job is suspended because paper has run out during the job, the next job is not processed even after the designated suspension time elapses.
» Settings/Registration » Function Settings » Common » Paper Feed Settings » Enabling Timeout for Suspended Jobs
08JK-08W
