Switching the Copy Basic Features Screen
You can specify the screen that appears when you press [Copy].
If [Copy Screen Display Settings] is set to 'Regular Copy':
If [Copy Screen Display Settings] is set to 'Express Copy':
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
Press [Preferences] → [Display Settings] → [Copy Screen Display Settings].
Specify the settings → press [OK].
