Take care when handling the optional equipment that is attached to the machine. When an optional unit's cover is opened to replace a staple cartridge, discard the punch waste/trim waste/staple waste, or clear paper or staple jams, prints may still be output if other optional units are operating normally, and are not involved in the paper or staple jam removal procedure.
When the punch waste tray is full, you cannot make copies or prints using the Hole Punch mode.
The Puncher Unit-BF1 is an optional product.
The Puncher Unit-BF1 is available only when the Staple Finisher-K1 or Booklet Finisher-K1 is attached.
Make sure that the punch waste tray is completely emptied.
If the punch waste tray is not securely in place, you cannot make copies or prints in the Hole Punch mode.
CAUTION |
When closing the front cover of the finisher, be careful not to get your fingers caught, as this may result in personal injury.
