The Duplex Color Image Reader Unit-F1 is optional products.
1. Pull the lever, and open the feeder cover.
2. Remove any jammed originals.
If there is difficulty in removing jammed paper, do not try to remove it forcibly, and proceed to step 3.
1.Turn the green feed dial.
2.Remove any jammed originals.
1. Close the inner cover.
2. Close the feeder cover.
CAUTION |
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
1. Lift the feeder.
3. Close the feeder.
CAUTION |
When closing the feeder, be careful not to get your fingers caught, as this may result in personal injury.
Be aware that the light emitted from the platen glass may be very bright when closing the feeder.
If there is difficulty in removing jammed paper, close the feeder and open the feeder cover and the inner cover, and then proceed to step 4.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
