Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Selecting the Code for Document Scan Lock (TL Code/QR Code)
Document Scan Lock Settings (TL Code)
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode (TL Code)
Adjusting the TL Code
Document Scan Lock Settings (QR Code)
Specifying the Document Scan Lock Operational Settings (QR Code)
Setting the Document Scan Lock Mode (QR Code)
Setting the Document Scan Lock Mode and Secure Watermark (QR Code)
Adjusting the QR Code Print Position
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Limiting Functions
Limiting Functions When the Security Key Is Turned OFF
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Setting to Disable Integrated Authentication
06RH-242
You can restrict the whole Integrated Authentication functions, regardless of authentication method settings. If you disable Integrated Authentication, entering the authentication information is required in specific operations as using login information of the machine for other authentication will be restricted.
The specific operations are as follows:
Sending to personal folders
Sending to an LDAP server
Sending to a file server
Using the Advanced Box
Using other functions which support Integrated Authentication
To disable integrated authentication method, it is necessary to access and then log in to the machine from a Web browser. This section describes the procedure for accessing the machine from the portal page of the Remote UI.
If you disable Integrated Authentication, an authentication error may occur when sending files to personal folders. If you want to disable Integrated Authentication while specifying the personal folders under the home folder, make sure to register authentication information for each user.
You can specify the personal folder settings in [Personal Folder Specification Method] in [Function Settings] (Settings/Registration). For more information, see "Specifying Personal Folders."
For information whether the login service or other services you are using support Integrated Authentication, contact your local authorized Canon dealer.
Start your Web browser → enter the following URL in the address bar.
http://<IP address of the machine or host name>
The [Login] page is displayed.
Enter each item → click [Administrator Login].
The following screen displays the default settings. If the Department ID Management or authentication for SSO-H is set, enter the necessary items for each log in.
Click [Shared Credential Management Service] on the Remote UI portal page.
4.
Select the item for <Setting to Disable Integrated Authentication> → click [Update].
Details of each item are shown below:
[Disable integrated authentication]:
Disable integrated authentication function, regardless of the authentication method.
[Disable integrated authentication using credentials for local device authentication]:
Disable integrated authentication when using authentication method of local device authentication.
[Disable integrated authentication using credentials for LDAP server authentication]:
Disable integrated authentication when using authentication method of LDAP server authentication.
Changes to the settings are enabled after the machine is restarted.
