Inner Finisher-E1 (Optional)
Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Inner Finisher-E1 is an optional product.
If the Paper Deck Unit-B2 is attached, move the paper deck unit away from the main unit before
proceeding with this procedure.
If there is paper in the output tray, remove the output paper before proceeding with this procedure.
If the Copy Tray-J1 is attached to the main unit, remove all output paper from the tray.
Remove any jammed paper from the output unit in accordance with steps 2 and 3 of "Main Unit."
Remove any jammed paper from the inner guide.
1. Pull down the inner guide.
2. Remove any jammed paper.
Remove any jammed paper protruding from the finisher's output tray.
4.
Push the paper output unit back into its original position.
CAUTION
When pushing the paper output unit back into its original position, be careful not to get your fingers caught, as this may result in personal injury.
5.
Close the upper right cover and then close the lower right cover.
CAUTION
When closing the upper and lower right covers of the main unit, be careful not to get your fingers caught, as this may result in personal injury.
Gently close the covers until they click into place in the closed position.
If the Paper Deck Unit-B2 was moved away from the main unit, reconnect it to the main unit.
6.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
» Problem Solving » Clearing Paper Jams » Inner Finisher-E1 (Optional)
06RH-0JK
