The maximum size of an image that you can send at 600 x 600 dpi resolution is 11" x 17". If the image exceeds this size, it may be cut off.
If you send a long strip original at 600 x 600 dpi, the periphery of the original image may be cut off slightly.
If [OOXML] is selected as the file format, you can only send in [300x300 dpi] or [600x600 dpi].
