If a problem frequently occurs when using the Finishing modes, such as Offset Collate and Staple, you can temporarily limit the use of these finishing modes by setting Limited Functions Mode to 'On'.
In addition, when the Service Call Message screen appears indicating a finishing mode malfunction and you temporally set the Limited Functions Mode to clear the Service Call Message screen, you can deactivate the Limited Functions Mode by setting this mode to 'Off' from the Settings/Registration screen. However, after the Limited Functions Mode is deactivated, the Service Call Message screen may appear again, unless the cause of the malfunction is cleared.
(See "Service Call Message.")
For information on the optional products required to use this function, see
"Optional Products Required for Each Function."
Press
(Settings/Registration).
Press [Management Settings] → [Device Management] → [Limited Functions Mode].
Press [On] → [OK].
Press [Off] to not use the limited functions mode.
This mode is enabled only after you restart the machine. For instructions on restarting the machine (turning the main power switch OFF, and then ON), see "Main Power and Energy Saver Key."
