Shutting Down the Machine from the Remote UI
You can shut down the machine from the Remote UI using the Remote Shutdown mode.
The shutdown process is performed even when the machine is executing a job.
When the machine is shut down, all jobs currently underway are canceled. Make sure that all jobs are complete before shutting down the machine.
Click [Settings/Registration] → select [Device Management] for <Management Settings>.
Click [Remote Shutdown] → [Start].
» Remote UI » Shutting Down the Machine from the Remote UI
06RH-1Y5
