Top » Optional Products/Software » Paper Deck Unit-B2
Paper Deck Unit-B2
06RH-03K
If you attach the Paper Deck Unit-B2 to the machine, you have one additional paper source for print jobs.
The Paper Deck Unit-B2 holds up to 2,700 sheets of paper (20 lb bond (80 g/m2)).
If the machine is in the Sleep mode (the touch panel is not displayed, and only (Energy Saver) is lit), you may be unable to open the paper deck. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the paper deck.
Parts and Their Functions
Release Button
Press to move the paper deck away from the main unit when you want to detach it from the machine.
Open Button
Press to open the paper deck when you need to load paper or to check for a paper jam.
Paper Supply Indicator
Enables you to check the amount of paper remaining in the paper deck.
4.
Paper Deck
Up to 2,700 sheets of paper (20 lb bond (80 g/m2)) can be loaded.
You can load only LTR paper into the paper deck unit.
