Platen Cover Type S
The Platen Cover Type S secures the documents placed on the platen glass.
Printer Cover-C2
The Printer Cover-C2 covers the top of the machine when the scanner unit is not attached.
Copy Card Reader-F1
The Copy Card Reader-F1 enables Department ID Management to be performed.
4.
Utility Tray-A2
The Utility Tray-A2 provides space to place originals.
5.
Copy Tray-J1
The Copy Tray-J1 provides an additional paper output tray.
6.
Paper Deck Unit-B2
The Paper Deck Unit-B2 provides an additional source of paper for printing jobs.
The Paper Deck Unit-B2 holds up to 2,700 sheets of paper (20 lb bond (80 g/m2)).
7.
Cassette Feeding Unit-AD2
The Cassette Feeding Unit-AD2 provides two additional sources of paper for printing jobs. Each paper drawer holds up to 550 sheets of paper (20 lb bond (80 g/m2)).
8.
Staple-J1
The Staple-J1 can be attached to the finisher for stapling (Corner and Double).
9.
Inner Finisher-E1
The Inner Finisher-E1 is equipped with the following features: Collate, Group, Offset, and Staple (Corner and Double).
10.
Tab Feeding Attachment Kit-B1/Envelope Feeder Attachment-D1
The Tab Feeding Attachment Kit-B1 can only be attached to Paper Drawer 2, and holds only Tab papers. The Envelope Feeder Attachment-D1 can only be attached to Paper Drawer 2, and holds only envelopes.
11.
Inner 2 Way Tray-F1
The Inner 2 Way Tray-F1 is equipped with the following features: Collate, Group, and Rotate.
12.
Staple Finisher-J1
The Staple Finisher-J1 is equipped with the following features: Collate, Group, Offset, and Staple (Corner and Double).
13.
Buffer Pass Unit-G1
The Buffer Pass Unit-G1 is required to attach the Staple Finisher-J1 or Booklet Finisher-J1 to the main unit.
14.
External 2/3 Hole Puncher-B2
The Puncher is equipped with the Hole Punch mode. The Puncher can be attached only if the Staple Finisher-J1 or Booklet Finisher-J1 is attached.
15.
Staple Cartridge-D2/Staple Cartridge-D3
The Staple Cartridge-D2/Staple Cartridge-D3 can be attached to the Booklet Finisher-J1 for saddle stitching.
16.
Booklet Finisher-J1
The Booklet Finisher-J1 is equipped with the following features: Collate, Group, Offset, Staple (Corner, Double, and Saddle Stitch), and Saddle Fold.
