Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Menu for Administrators » Setting the Security for SSO-H » Allowing Administrators to Operate Using the Default Password
06RH-229
You can set the machine to not display the screen for changing the password when a System Administrator (Administrator) logs in to the machine using the default user name and password from the touch panel display.
If you use the default password with SSO-H, security issues may arise. It is recommended that you change the password to use SSO-H.
If the password has expired, the screen for changing the password appears, regardless of this setting.
Click [Security Settings].
Select [Allow administrators to operate using default password].
Click [Update].
