Customizing the Screen Display
06RH-290
The imageRUNNER ADVANCE enables you to customize the screen display of the touch panel display. By placing buttons for frequently used functions in a visible position, or creating a shortcut keys for combinations of functions that are frequently used, you can increases the efficiency of operations.
Customizing the Main Menu Display
Operating a Series of Functions with One Button
For example, if you register function that is to scan 2-sided originals and send the data to your computer as a compact PDF, you can operate this series of functions with the press of one button.
Recalling Settings Used on Another Machine
If you register the Quick Menu button, which stores a series of functions, you can also use that setting on another machine without registering again.
