Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Copy Security with Forced Document Scan Lock and Secure Watermark
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Advanced Copying and Printing » Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
06RH-28S
When the machine is processing a job, you cannot start a new job until the current job is complete. For instance, if a large copy job is processing, you must wait until the copy job is completely finished. In this case, you can use the Reserved Copying mode to scan originals while a copy job is processing, and start copying right after the current job is complete. Specifying to receive a notice when your copy job is complete also helps you to effectively process the copy job.
Benefits of Reserved Copying
You can set the machine to scan originals while it is processing a job. This function enables you to start copying right after the current job is complete. The Reserved Copying mode can also be set while the machine is in the waiting state.
Benefits of Job Done Notice
This mode enables you to be notified at your desk when the job is complete. To use the Job Done Notice mode, you need to store your e-mail addresses in the Address Book beforehand.
Required Condition
E-mail settings are set.
This section describes the procedure for scanning originals while the machine is processing a copy job, and sending a job done notice to the specified e-mail address.
The screens may differ, depending on the model of the machine and on attached optional products.
Press [Close] on the pop-up screen that appears while the machine is printing.
Place your originals → set the desired copy modes and paper source.
Press [Options] on the Copy Basic Features Screen.
4.
Press [Job Done Notice].
5.
Select the destination where the job done notice is to be sent → press [OK].
You cannot select multiple destinations at one time.
6.
Press (Start) to specify reserved copying.
Copying of the new job automatically begins when the current job is complete. If the message <Cannot print because job reservations are full or the printer is warming up. Wait a while, then try again.> is displayed, press [OK] → try reserving the job again after the current job is complete.
Once reserved copying is complete, a job done notice is sent to the selected destination.
