If the machine is connected by unidirectional communication, you must set the fax options (such as the fax board) attached to and installed in the machine manually.
If the machine is connected by bidirectional communication, the settings for this procedure are disabled. Follow the procedure in "Verifying the Fax Information" to automatically set the options.
Open [System Preferences] → click [Print & Fax].
Select the fax you are using → click [Options & Supplies].
Click [Driver] → confirm that your fax is selected for [Print Using] → configure the options installed in the fax.
Be sure to select only those options that are actually installed in the fax.
4.
Click [OK].
» Fax » Sending a Fax from a Computer (Mac) » Before Sending a Fax from a Computer » Setting the Fax Options » Manually Setting the Fax Options
07SE-0W1
