Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed original.
 CAUTION
When removing jammed originals, take care not to cut your hands on the edges of the originals.
Remove originals from the original supply tray.
Remove any original jammed in the feeder cover.
If there is difficulty in removing jammed original, do not try to remove it forcibly, and proceed to step 3.
1. Pull the lever, and open the feeder cover.
2. Remove any jammed original.
Open the inner cover, holding it by its front tab.
4.
Turn the feed dial inside the feeder cover in the direction of the arrow (clockwise), and remove any original jammed in the feeder cover.
1. Turn the feed dial to the right.
2. Remove any jammed paper.
5.
Remove any original jammed in the output tray.
1. Turn the feed dial to the left.
2. Lift the original supply tray.
3. Remove any jammed paper.
6.
Close the feeder cover.
1. Close the inner cover.
2. Close the feeder cover.
 CAUTION
When closing the covers, be careful not to get your fingers caught, as this may result in personal injury.
7.
Remove any paper jammed in the feeder.
If it is difficult to remove the jammed original, turn the feed dial counterclockwise.
 CAUTION
When closing the feeder, be careful not to get your fingers caught, as this may result in personal injury.
Be aware that the light emitted from the platen glass may be very bright when closing the feeder.
8.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
