(Settings/Registration). |
Before setting <Use SSL> to 'On', it is necessary to set a default key in [Preferences] (Settings/Registration). (See "Setting the Key Pair Used With SSL Encrypted Communications.")
Any changes made to <Use SSL> are also applied to [Use SSL] in [MEAP Settings] in [Management Settings] (Settings/Registration). (See "MEAP Settings.")
For more information on the Remote UI, see "Remote UI."
Changes are only effective after you restart the machine (the main power switch is turned OFF, and then back ON). For instruction on restarting (turning the main power switch OFF and then ON) the machine, see "Main Power and Energy Saver Key."
