On
Please note that the memory of the machine can store up to 6,000 pages. When you send a secured
document to be stored in the memory to be printed at a later time, and the memory is full (already
reached its maximum capacity), your document will not be stored. The memory may be full because the machine is being used for other functions (such as storing a form) or other jobs, which use memory space.
This function can only be selected if the Booklet Finisher-M1 is attached to the machine.
This function is not available if 'Booklet' is set to [Off].If the print job contains only one sheet of paper, the paper will be folded but not stapled.
The maximum number of sheets that can be saddle stitched is 16. If the number of sheets is greater than this, they will not be saddle stitched.
