(Settings/Registration).|
Even if this function is set to 'On', the machine does not startup quickly in the following situations:
When any of the network settings below are set to 'On'
RARP
BOOTP
IPsec
IPv6
NetWare
AppleTalk
When turning ON the main power of the machine after turning OFF the main power in any of the conditions below
More than 110 hours have elapsed after quick startup
Operating jobs
Jobs are reserved
Just after using telephone lines
Backing up data
Accessing to the machine via network
After specifying settings which require restarting the machine
Error is occurred
Using the Limited Functions mode
The power cord is disconnected after turning OFF the main power
MEAP applications which do not support quick startup are installed on the machine
When turning ON the main power of the machine in 20 seconds after turning OFF the main power
When turning ON the main power of the machine after turning OFF the main power from the Remote UI
If you set the quick startup, the tone sounds when turning ON/OFF the main power of the machine. (Depending on the situations, the machine does not startup quickly and the tone does not sound.)
