Scaling Documents
You can enlarge or reduce the size of the document to be printed.
There are two methods for scaling a document: select the paper size to be printed to scale it automatically, or specify the scaling value manually.
Select [Page Setup] from the [File] menu of the application.
Depending on the application you are using, the [Page Setup] dialog box may not be displayed. If this is the case, specify the following settings from the [Print] dialog box displayed by selecting [Print] from the [File] menu.
Select [Page Attributes] from [Settings] → select your printer from [Format for] → select a paper size for printing from [Paper Size].
Where the paper size specified in the application and that specified in this preferences pane differ, scaling is set automatically.
If you want to increase or decrease the magnification manually, specify the zoom ratio for [Scale].
Click [OK].
4.
Select [Print] from the [File] menu.
5.
Select your printer → specify the desired settings →click [Print].
Depending on the printer model you are using, you may not be able to magnify the document to the optimum ratio for the selected page size.
The screen may vary according to the operating system, as well as the type and version of the printer driver.
» Print » Printing from a Computer (Mac) » Scaling Documents
0CYL-2CC
