The procedure for configuring the page settings prior to printing is as follows.
Select [Page Setup] from the [File] menu of the application.
Select [Page Attributes] from [Settings].
Select your printer from [Format for] → set [Paper Size], [Orientation], and [Scale] as necessary.
4.
Select [Save As Default] from [Settings] → click [OK].
The settings are saved as the default settings.
Depending on the application you are using, the [Page Setup] dialog box may not be displayed.
The screen may vary according to the operating system, as well as the type and version of the printer driver.
» Print » Printing from a Computer (Mac) » Printing Fundamentals » Configuring the Default Page Settings
0CYL-2C9
