If the machine is connected by unidirectional communication, you must set the printer options (such as paper feed options, paper output options, etc.) attached to and installed in the machine manually.
Open [System Preferences] → click [Print & Scan] (or [Print & Fax]).
Select the printer you are using → click [Options & Supplies].
Click [Driver] → configure the options installed in the printer.
Be sure to select only those options that are actually installed in the printer.
Be sure to set the function version of the printer you are using correctly. The function version is printed in the status sheet that can be printed from the control panel of the printer.
If you are using Mac OS X 10.7 or earlier, check that the driver corresponding to the printer you are using is selected for [Print Using]. For the driver name corresponding to your printer, refer to the Readme file.
4.
Click [OK].
» Print » Printing from a Computer (Mac) » Before Printing from a Computer » Setting the Printer Options » Manually Setting the Printer Options
0CYL-2C5
