You can attach a cover sheet to an outgoing fax.
Select [Print] from the [File] menu of the application.
Select your fax → select [Cover Sheet].
Select an option for attaching the cover sheet from [Cover Sheet Attachment] → select a cover sheet template from [Style].
4.
If you want to specify the items to include on the cover sheet, click [Item Settings].
If you do not want to specify the items to include on the cover sheet, proceed to step 9.
5.
If you want to add an attention note, select [Insert Attention Note] → select a label.
You can also enter a customized label instead of one of the pre-defined labels.
Enter any other information in [Comment to include] as necessary.
6.
Click [Sender] → select items you want to print on the cover sheet regarding the sender → enter the information.
7.
Click [Destination] → select items you want to print on the cover sheet regarding the destination.
The destination information specified in the address book is automatically printed on the cover sheet.
8.
If you want to include the number of pages or a title, click [Details] → relevant item and enter the required content.
The number of pages sent is not automatically calculated. The number of pages entered in this tab is displayed on the cover sheet.
9.
Click [Print].
The specified cover sheet is attached to the fax when it is sent.
The maximum number of destinations you can send a fax to at any one time differs depending on whether a cover sheet is attached to the fax. For details, refer to the Readme file.
The display may vary according to the operating system and fax driver version you are using.
