Setting the Output Range
You can set the range of pages to be sent.
Select [Print] from the [File] menu of the application.
Select your fax → set [Pages].
If you want to send only a part of the document, enter the first and last page numbers.
Click [Print].
The specified range of pages in the document is sent.
Because only one copy is sent when using the fax driver, the [Copies] and [Collated] settings are ignored.
Depending on the application you are using, you cannot set the output range in the upper part of the [Print] dialog box. If this is the case, display and set the function in the [Copies & Pages] preferences pane.
» Fax » Sending a Fax from a Computer (Mac) » Setting the Output Range
0CYL-288
