If the machine is connected by unidirectional communication, you must set the fax options attached to and installed in the machine manually.
Open [System Preferences] → click [Print & Scan] (or [Print & Fax]).
Select the fax you are using → click [Options & Supplies].
Click [Driver] → configure the options installed in the fax.
Be sure to select only those options that are actually installed in the fax.
If you are using Mac OS X 10.7 or earlier, check that the driver corresponding to the fax you are using is selected for [Print Using]. For the driver name corresponding to your fax, refer to the Readme file.
4.
Click [OK].
» Fax » Sending a Fax from a Computer (Mac) » Before Sending a Fax from a Computer » Setting the Fax Options » Manually Setting the Fax Options
0CYL-283
