Feeder Jam Recovery Method
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
If you are using the imageRUNNER ADVANCE 4235/4225, this mode can be set when the DADF-AG1 is attached. (See "DADF-AG1.")
Press [Function Settings] → [Common] → [Scan Settings].
Press [Feeder Jam Recovery Method].
4.
Specify the following setting → press [OK].
Details of each item are shown below.
[From 1st Page]:
If a paper jam occurs in the feeder, scanning starts again from the first page of the document.
[From Suspnd. Original]:
If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
The [From Suspnd. Original] setting is disabled when using the Direct Sending mode of the Fax function, and the Scan and Send function.
» Settings/Registration » Function Settings » Common » Scan Settings » Feeder Jam Recovery Method
0CYL-271
