System Requirements
The following system environments are necessary in order to use the fax driver.
Operating Systems:
Windows XP
Windows Server 2003
Windows Server 2008
Windows Vista
Windows 7
Windows 8
Windows Server 2012
Computer:
Any computer that runs the above systems
Memory:
Any memory with the capacity required to operate the compatible operating systems
Supported operating systems may differ according to the fax driver version you are using.
Depending on the printer model, you may need to specify a queue as described below.
LPR
For Windows TCP/IP, enter either <Print>, <Hold>, or <Direct> as the queue.
RAW
The following four port numbers are available:
9100: Enter either <Print>, <Hold>, or <Direct> as the queue.
9101: The queue will be set to <Direct>.
9102: The queue will be set to <Print>.
9103: The queue will be set to <Hold>.
SMB
Select any of the three queues displayed after selecting a printer from the network tree.
» Fax » Sending a Fax from a Computer (Windows) » System Requirements
0CYL-273
