Questions & Answers
The background you wanted to remove has been scanned in.
Perform the following steps:
Select [Background Density] for [Image Quality Adjstmnt] in the [Main] sheet.
Click [Fine Adjustment] → adjust each color by moving the sliders in the [Adjustments for Background Density] dialog box.
Images are bleeding through from the opposite side of the paper when scanning.
Dark borders and frame lines that appear around the original have been scanned.
Right-click in the Preview Area to display a pop-up menu.
On the pop-up menu, point to [Original Frame Erase] → click [On].
After the scanning progress bar in the [Transfer Pages] dialog box reaches 100%, the scanning stops and the computer takes a long time to read the data.
If the operating system includes the Windows Firewall function and that function has been enabled, it may take some time for scanning to finish. Verify whether UDP ports can be registered as exceptions are automatically registered at the time of installation. If the appropriate UDP port has not been registered, it will have to be registered manually.
[Name]: Enter a name
[Port number]: 56338
[Protocol]: Select [UDP]
For Windows 7:
Click [](Start) → [Control Panel] → [System and Security] → [Windows Firewall] → [Advanced Settings].
Select [Inbound Rules] in the [Windows Firewall with Advanced Security] sheet → click [New Rules].
In [New Inbound Rule Wizard], select [Port] → click [Next].
4.
Select [UDP] → enter 56338 in [Specific local port] → click [Next].
5.
Select [Allow the connection] → click [Next].
6.
Select only [Private] → click [Next].
7.
Enter a name in [Name] → click [Finish] to close [New Inbound Rule Wizard].
For Windows Vista/Windows Server 2008:
Click [](Start) → [Control Panel] → [Security] → [Windows Firewall] → [Allow a program through Windows Firewall].
In the [Exceptions] sheet, click [Add Port].
In the [Add a Port] dialog box, enter a name for [Name] → enter 56338 for [Port number] → select the check mark next to [UDP] → click [OK].
4.
Click [OK] and close the [Windows Firewall] dialog box.
For Windows XP/Windows Server 2003:
Click [Start] → [Control Panel] → [Security Center] → [Windows Firewall] under [Manage security setting for].
4.
The above procedures vary according to the edition and system settings of the operating system you are using.
» Scanner » Questions & Answers
0CYL-29A
