AppleTalk Network Setup Procedures
To print via an AppleTalk network, it is necessary to perform the following procedures.
1 Macintosh Network Settings
To specify AppleTalk network settings, enable AppleTalk according to the instructions in the documentation provided with your Macintosh.
2 Protocol Settings
Specify the protocol settings. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Canon utilities
3 Setting Up a Computer for Printing
Specify the settings for each computer you use for printing.
Depending on the machine you are using, you may have to use optional equipment to print via an AppleTalk network. For the equipment needed, see "Optional Equipment and System Requirements."
It is recommended that you consult the administrator for the network you are using when performing the settings in step 2.
» Network » AppleTalk Network Setup Procedures
0CYL-1S4
