Optional Equipment
Platen Cover Type R
The platen cover secures the documents placed on the platen glass.
DADF-AG1
The scanner unit scans documents placed on the platen glass, and the feeder sends the documents you have loaded one by one to the platen glass. If you are using the imageRUNNER ADVANCE 4251/4245, the DADF-AG1 is standard-equipped.
Copy Card Reader-F1
The Copy Card Reader-F1 enables Department ID Management to be performed.
4.
Utility Tray-A2
The Utility Tray-A2 provides space to place originals.
5.
Paper Deck Unit-B2
The Paper Deck Unit-B2 provides an additional source of paper for printing jobs.
The Paper Deck Unit-B2 holds up to 2,700 sheets of paper (21 lb bond (80 g/m2)).
6.
Cassette Feeding Unit-AF1
The Cassette Feeding Unit-AF1 provides two additional sources of paper for printing jobs.
Each paper drawer holds up to 550 sheets of paper (21 lb bond (80 g/m2)).
7.
Inner 2/3 Hole Puncher-A1
The Inner 2/3 Hole Puncher-A1 is equipped with the Hole Punch mode.
8.
Inner Finisher-D1
The Inner Finisher-D1 is equipped with the following features: Collate, Group, and Staple (Corner and Double).
9.
Inner 2Way Tray-H1
The Inner 2Way Tray-H1 is equipped with the following features: Collate, Group, and Rotate 90 Degrees.
10.
Staple-J1
The Staple-J1 can be attached to the finisher for stapling (Corner and Double).
11.
Staple Finisher-G1
The Staple Finisher-G1 is equipped with the following features: Collate, Group, and Staple (Corner and Double).
12.
USB Device Port-E3
The USB Device Port-E3 is required to attach the Multimedia Reader/Writer-A2 to the machine.
13.
Buffer Pass Unit-H1
The Buffer Pass Unit-H1 is required to attach the Staple Finisher-G1 or Booklet Finisher-G1 to the machine.
14.
Envelope Feeder Attachment-D1
The Envelope Feeder Attachment-D1 can only be attached to Paper Drawer 2, and holds only envelopes.
15.
External 2/3 Hole Puncher-B2
The External 2/3 Hole Puncher-B2 is equipped with the Hole Punch mode.
16.
Staple Cartridge-D2
The Staple Cartridge-D2 can be attached to the Booklet Finisher-G1 for saddle stitching.
17.
Booklet Finisher-G1
The Booklet Finisher-G1 is equipped with the following features: Collate, Group, and Staple (Corner, Double, and Saddle Stitch).
» Optional Products/Software » System Configuration » Optional Equipment
0CYL-038
