Consumables
The following consumables are available from Canon. For more information, contact your local authorized Canon dealer.
We recommend that you order paper stock and toner from your local authorized Canon dealer before your stock runs out.
Recommended Paper
In addition to plain paper (11" x 17", LGL, and LTR size), recycled paper, color paper, transparencies (recommended for this machine), tracing paper, labels, and other types of paper stock are available. For more information, contact your local authorized Canon dealer.
CAUTION
Do not store paper in places exposed to open flames, as this may cause the paper to ignite, resulting in burns or a fire.
Some commercially available paper types are not suited for this machine. Contact your local authorized Canon dealer when you need to purchase paper.
To prevent moisture build-up, tightly wrap any remaining paper in its original package for storage.
For high-quality printouts, use paper recommended by Canon.
Toner
If a message prompting you to replace the toner cartridge appears on the touch panel display, replace the used toner cartridge with a new one.
For optimum print quality, using Canon genuine toner is recommended.
Product Name
Supported Canon Genuine Toner
imageRUNNER ADVANCE 4251/4245
Canon GPR-42 Black Toner
imageRUNNER ADVANCE 4235/4225
Canon GPR-43 Black Toner
WARNING
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite, resulting in burns or a fire.
Do not store toner cartridges in places exposed to open flames, as this may cause the toner to ignite, resulting in burns or a fire.
If you accidentally spill or scatter toner, carefully wipe up the loose toner with a damp, soft cloth and avoid inhaling any toner dust. Do not use a vacuum cleaner that is not equipped with safety measures to prevent dust explosions to clean up loose toner. Doing so may cause damage to the vacuum cleaner or result in a dust explosion due to static discharge.
CAUTION
Keep toner out of the reach of small children. If toner is ingested, consult a physician immediately.
Store toner cartridges in a cool location, away from direct sunlight. (The recommended storage conditions are temperatures below 86 °F and humidity below 80%.)
[Be careful of counterfeit toners]
Please be aware that there are counterfeit Canon toners in the marketplace. Use of counterfeit toner may result in poor print quality or machine performance. Canon is not responsible for any malfunction, accident or damage caused by the use of counterfeit toner.
For more information, see http://www.canon.com/counterfeit.
Stamp Cartridge
The stamp cartridge is used to stamp originals. Use the tweezers provided to remove and replace the stamp cartridge.
Stamp Ink Cartridge-C1
Staple Cartridge
Finisher
Staple Cartridge
Name
Shape
Booklet Finisher-G1
Staple Cartridge-D2
Staple Finisher-G1
Booklet Finisher-G1
Inner Finisher-D1
Staple-J1
Genuine Supplies
Canon has developed and manufactured Toner, Parts, and Supplies specifically for use in this machine. For optimal print quality and for optimal machine performance and productivity, we recommend that you use Genuine Canon Toner, Parts, and Supplies.
Contact your Canon Authorized Dealer or Service Provider for Genuine Canon Supplies.
» Maintenance » Consumables
0CYL-0H7
