Removing Punch Waste from the Inner 2/3 Hole Puncher-A1
When the punch waste tray of the Puncher becomes full, a screen prompting you to remove the punch waste appears on the touch panel display.
Follow the procedure described below to remove the punch waste.
The Inner 2/3 Hole Puncher-A1 is an optional product.
The Inner 2/3 Hole Puncher-A1 is available only if the Inner Finisher-D1 is attached.
Pull out the punch waste tray.
1. Open the front cover of the inner finisher.
2. Pull out the punch waste tray.
Discard the punch waste.
Make sure that the punch waste tray is completely emptied.
Return the punch waste tray to its original position.
1. Push the punch waste tray back into its original position.
2. Close the front cover of the inner finisher.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
If the punch waste tray is not securely in place, you cannot make prints in the Hole Punch mode.
» Maintenance » Removing Punch Waste (For Optional Products) » Removing Punch Waste from the Inner 2/3 Hole Puncher-A1
0CYL-0H0
