Loading Transparencies
You can load transparencies only in the multi-purpose tray.
Transparencies have a front and back side. Load transparencies correctly to achieve sharp printing results.
The side facing down is the one printed on.
You can load only LTR size transparencies.
When loading transparencies, make sure to hold only the edges of the sheets and avoid touching the print surface.
Do not load transparencies while the machine is printing. Doing so may cause a paper jam.
Use only transparencies intended for use with this machine. If you use other transparencies, you may cause damage to the machine.
It is recommended that output transparencies are immediately removed from the output tray to avoid folding of the transparencies and paper jams.
Return the remaining transparencies to their original package for storage, avoiding locations subject to high temperatures and humidity. Leaving transparencies loaded for an extended period of time may cause the sheets to stick together and result in a paper jam.
Leaving transparencies loaded for an extended period of time may cause the sheets to stick together and result in difficulties feeding the transparencies. In this case, fan the loaded transparency sheets, or if you have loaded 50 or more sheets, reduce the number of sheets to less than 50 or use new transparencies.
When printing on transparencies, depending on the type of image, the image may become dense. When this happens, adjust the density for the output image.
If a paper jam occurs, fan the loaded transparency sheets well.
» Maintenance » Loading Paper » Loading Transparencies
0CYL-0FH
