Matching the Print Side for 1-Sided and 2-Sided Printing
You can print on paper with printed logos while taking into account the print side (front/back) by using [Print Side Priority]. This mode enables you to print the first page of your original on the front side for both 1-sided and 2-sided prints without changing the orientation of the paper.
Printing Example
Paper with Printed Logos
Original
Front Side
Back Side
1-Sided Printing
2-Sided Printing
Prints each page on the front side.
Prints odd numbered pages (first, third, etc.) on the front side.
To achieve the above print results, load paper in the orientations indicated below.
Printing Method
Paper Source
Paper Load Orientation
When [Speed Priority] is set
1-Sided Printing
Paper Drawer
Front side facing up
Multi-Purpose Tray
Front side facing down
2-Sided Printing
Paper Drawer
Multi-Purpose Tray
When [Print Side Priority] is set
1-Sided/2-Sided Printing
Paper Drawer
Multi-Purpose Tray
If you select [Print Side Priority] for a paper source, the Automatic Paper Selection and Paper Drawer Auto Selection settings are ignored. Also, the machine's printing speed may become slower when you print one-sided documents.
To print using the [Print Side Priority] settings, load the paper indicated below. For other paper, the message <Load paper.> appears and the paper is not fed, or the [Print Side Priority] settings are disabled.
Paper size: 11" x 17", LTR, LTRR, STMTR
Paper weight: 16 lb bond to 28 lb bond (60 g/m2 to 105 g/m2)
Paper type: Plain, Color, Recycled, Heavy 1, Pre-Punched (LTR and LTRR only)
Press [Function Settings] → [Common] → [Paper Feed Settings].
Press [Feed Method Switch].
4.
Press [Print Side Priority] for each paper source → [OK].
» Settings/Registration » Function Settings » Common » Paper Feed Settings » Matching the Print Side for 1-Sided and 2-Sided Printing
0CYL-075
