If the machine is used as a network printer, you can store data in the machine from a computer via the network printer.
For instructions on placing originals, see "Placing Originals."
If you make a mistake when entering the mail box number using the numeric keys, press [Cancel] → enter the correct mail box number.
You cannot use the following characters in a file name: \ / : , * ? " < > |
You cannot use a . (period) or space for the first or last character of the file name.
The full pathname, including folders and the file name, must not exceed 256 characters in length.
If you create a file without assigning it a name, the machine automatically assigns the file a name using the year, month, day, and time the file was created.
For example, if a file is created at 1:35 PM, 41 seconds, on 01.15.13, its name will be <20130115133541>. If you enter a file name that already exists, (1) to (9) is added to the file name.
Example: a(1).pdf |
To cancel scanning, press [Cancel] or
If you want to scan a color image, it is necessary to expand the memory capacity of the machine with the Additional Memory Type A (512MB).
You can scan and store up to 999 pages at one time. If two-sided originals are scanned using the feeder, you can store up to 1,000 pages. Once the maximum number of originals you can scan is reached, a message asking whether to store appears.
To check whether the file was stored correctly, press
