Advanced Box/Network Settings
There are two types of storage locations in the Advanced Box; Shared Space and Personal Space. To use these storage locations, it is necessary to specify their settings. The administrator has to specify the various settings such as the user authentication management, allowing use of Personal Space, and Open to Public settings, according to your needs.
Advanced Box User Authentication Management Settings
The following settings are required to perform authentication management for users of the Advanced Box.
Register the users to perform authentication management for in "User Access Control for Advanced Box" (login service). (See "User Access Control for Advanced Box.")
Set [Authentication Management] to 'On' in [Advanced Box Settings] in [Function Settings] (Settings/Registration). (See "Setting the Advanced Box to Be Opened Externally as a WebDAV/SMB Server.")
Allowing Users to Use the Personal Space
In addition to the above "Advanced Box User Authentication Management Settings," the following setting is required to allow users to use the Personal Space.
Set [Allow to Create Personal Space] to 'On' in [Function Settings] (Settings/Registration). (See "Allowing to Create Personal Spaces.")
Opening the Advanced Box Using SMB or WebDAV
The settings below are required to open the Advanced Box to the public using SMB or WebDAV. This enables you to open the Advanced Box of the machine to be used as network place, and enables the Advanced Box to be used from computers.
For SMB:
Set [Open to Public] to 'By SMB' in [Function Settings] (Settings/Registration). (See "Setting the Advanced Box to Be Opened Externally as a WebDAV/SMB Server.")
Set [Use SMB Server] to 'On' in [Preferences] (Settings/Registration). (See "SMB and WINS Settings.")
If the Advanced Box is open to the public by setting [Authentication Management] to 'On' in [Advanced Box Settings] in [Function Settings] (Settings/Registration), set the authentication type by setting [Use SMB Authentication] to 'On' in [SMB Auth. Settings] in [Preferences] (Settings/Registration). (See "SMB and WINS Settings.")
For information on the SMB server settings, see "SMB and WINS Settings."
To allow external users to write in the Advanced Box, set [Prohibit Writing from External] to 'Off' in [Function Settings] (Settings/Registration). (See "Prohibiting Writing from External Users.")
For WebDAV:
Set [Open to Public] to 'By WebDAV' in [Function Settings] (Settings/Registration). (See "Setting the Advanced Box to Be Opened Externally as a WebDAV/SMB Server.")
Set [Use WebDAV Server] to 'On' in [Preferences] (Settings/Registration). (See "Settings Common to TCP/IPv4 and TCP/IPv6.")
If the Advanced Box is open to the public by setting [Authentication Management] to 'On' in [Advanced Box Settings] in [Function Settings] (Settings/Registration), set the authentication type (Basic) in [WebDAV Server Settings] in [Advanced Box Settings] in [Function Settings] (Settings/Registration). (See "Setting the Advanced Box to Be Opened Externally as a WebDAV/SMB Server.")
If the machine shuts down when a client computer is writing a file to the Advanced Box, an incomplete file is generated inside the Advanced Box. In this case, perform the operation again after restarting the machine.
Using the Advanced Box of Another Machine
Configure the network as follows to enable this machine to use the Advanced Box (network storage) of another imageRUNNER ADVANCE series machine. The Advanced Box must be opened externally using SMB or WebDAV.
Settings on this machine:
Register the Advanced Box of another imageRUNNER ADVANCE series machine that is opened externally in [Network Place Settings] in [Function Settings] (Settings/Registration). (See "Setting/Managing the Advanced Box of an External Reference (Network Place).")
Set the same communication protocol used to open the Advanced Box of another imageRUNNER ADVANCE series machine externally in [Protocol for External Reference] in [Function Settings] (Settings/Registration). (See "Setting the Protocol for External Reference.")
Settings on the other imageRUNNER ADVANCE series machine:
If the external Advanced Box is open with authentication management set to 'On', register the users in "User Access Control for Advanced Box." (See "Registering User Information.")
Operating Systems Compatible as the Client of the SMB or WebDAV Server:
Windows XP
Windows Vista
Windows 7
Windows 8
To connect to the Advanced Box that is opened externally as the WebDAV server from a computer, depending on the operating system/software environment you are using, it is necessary to install the following update program.
For Windows XP or Windows Vista
Update Software Program for Web Folder: KB907306
For Office XP
Microsoft Office XP Service Pack 1 (SP-1)
For 2007 Office system
2007 Microsoft Office system Service Pack 1 (SP-1)
For more information, see the Microsoft Web page.
Questions & Answers
Q
The Advanced Box is open to public via SMB, but I cannot connect.
A
Check the SMB Authentication Settings for the SMB Server and Authentication Management for the Advanced Box. (See "SMB and WINS Settings" and "Setting the Advanced Box to Be Opened Externally as a WebDAV/SMB Server.")
For information regarding SMB Server and Advanced Box authentication settings, see the following table:
Authentication
Preferences → Network → SMB Server Settings
Function Settings → Store/Access Files → Advanced Box Settings → Authentication Management
Log In Using Touch Panel Display
Log In Using Client Computer
Use SMB Server
SMB Authentication Settings → Use SMB Authentication
On
On
On
Required
Required
On
Off
On
Required
No access
On
Off
Off
Not required
Not required
On
On
Off
Not required
Required
Q
The Advanced Box is open to public via WebDAV, but I cannot connect via WebDAV.
A
Check the ON/OFF setting for the WebDAV Server, Authentication Management for the Advanced Box, and Authentication Type for the WebDAV Server. (See "Setting the Advanced Box to Be Opened Externally as a WebDAV/SMB Server.")
For information regarding WebDAV Server and Advanced Box authentication settings, see the following table:
Authentication
Preferences → Network → TCP/IP Settings → Use WebDAV Server
WebDAV Server Settings → Authentication Type
On
On
Basic
Required
Required
On
On
Off
Required
No access
On
Off
Basic
Not required
Not required
On
Off
Off
Not required
Not required
If you are connecting from a computer, you may not be able to connect unless the port number is included in the access destination URL.
Check that you can connect using the following method:
If SSL is invalid: http://IP address:80/share
If SSL is valid: https://IP address:443/share
» Scan and Store » Overview of This Function » Advanced Box/Network Settings
0CYL-11U
