When the job is displayed on the machine's touch panel display or in the utility software, the main document and the banner page are displayed separately. If you cancel or change the print order of the main document, the banner page is still printed or mixed in with other print jobs unless it is also canceled or its order in the print queue is changed.
If several print jobs are sent to the machine at the same time, the banner page associated with the main document of a job may not printed immediately after the job, but in a different order.
If you are using the impression count setting for the Department ID Management function, the banner page is not counted as an impression. It is counted as a job with an unknown ID.
4.
Even if the main document is a secure print job, protected by a password, the banner page is not processed as a secure print job, and is printed immediately when it reaches the top of the print queue.
5.
If a print job is stored in an Inbox, the banner page is not stored in the inbox and is printed.
6.
If a print job containing a banner page is printed using a driver that is not specific to this machine, the print job may not be executed correctly.
7.
In models that is equipped with a fax function, a banner page is not considered a fax transmission job even if the print job is set up as a fax transmission, and only the banner page is printed.
