PDL Selection (Plug-n-play)
From the machine, you can specify functions suitable for the fax board or printer kit available for use in the machine.
From your computer, you can detect and install drivers that are compatible with the specified functions.
The PDL Selection (PnP) function is displayed only when at least one of the following options is available for use.
When the PCL Printer Kit or PS Printer Kit is activated.
When the optional fax board is installed.
If the desired driver is not in your computer, detection and installation cannot be performed.
Press [Function Settings] → [Printer] → [PDL Selection (Plug-n-Play)].
Select the button → press [OK].
The appeared function buttons may differ, depending on the optional equipment that is attached.
Changes are only effective after you restart the machine (the main power switch is turned OFF, and then back ON). For instruction on restarting (turning the main power switch OFF and then ON) the machine, see "Before You Start Using This Machine."
» Print » Setting the Machine (PS/PCL/UFR II Printer) » PDL Selection (Plug-n-play)
0CYL-1FE
