Enlarge Print Area
[On], [Off]*
This setting specifies whether to enlarge the printable area on the paper.
[On]
The printable area is enlarged to the top, bottom, left, and right edges of the paper.
[Off]
The area 1/8" (4 mm) from the top, bottom, left and right edges of the paper is not printable.
If you select [On], images on the edge of the paper may not print properly.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » PDF Settings » Enlarge Print Area
0CYL-1F1
