Personality
The machine can distinguish between computer-sent control commands and Direct Print data and automatically switch personalities. However, in instances such as where received control commands are exclusively defined or the machine does not automatically switch to the appropriate personality, please set the Personality to match received data. The machine enables you to switch the personality and set specifications for printing using the menu functions on the touch panel display.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Personality
0CYL-1AJ
