Combinations with options (system configurations) for using the machine as a printer are available as described below.
In this manual, the combinations are each defined with the terms UFR II Printer, PCL Printer, PS Printer, PDF Direct Print Printer, and XPS Direct Print Printer.
To enable these modes and functions, you must register the license key with the machine. For information on registering the license key, see "Security."
UFR II Printer
UFR II printing is standard with the imageRUNNER ADVANCE 4251/4245/4235/4225.
Machine Model
Required Option Kit
(UFR II Printer Kit is Standard.)
PCL Printer
The PCL Printer Kit must be activated for PCL printing.
Machine Model
Required Option Kit
PCL Printer Kit
PS Printer
The PS Printer Kit must be activated for PS printing.
Machine Model
Required Option Kit
PS Printer Kit
The Direct Print Kit (for PDF/XPS) must be activated for PDF Direct printing.
Machine Model
Required Option Kit
The Direct Print Kit (for PDF/XPS) must be activated for XPS Direct printing.
Machine Model
Required Option Kit
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Combinations and Names of Printer Kit Options
0CYL-1AF
