NetWare Network Setup Procedures
To use a NetWare network, it is necessary to perform the following procedures.
1 NetWare Print Service Settings
Specify the NetWare print service settings. (Optional equipment is required to print or send a fax from a computer. For information on the optional products required, see "Optional Equipment and System Requirements.") To specify the settings from the computer, use one of the following:
NWADMIN or PCONSOLE (Novell software provided with NetWare)
Canon utilities
2 Protocol Settings
Specify the protocol settings. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Canon utilities
3 Setting Up a Computer for Printing/Sending a Fax
Specify the settings of each computer you use for printing or sending a fax. (Optional equipment may be required for printing from computers and sending faxes, depending on the model of your machine. For information on the optional products required, see "Optional Equipment and System Requirements.")
It is recommended that you consult the administrator for the network you are using when performing the settings in steps 1 and 2.
To configure settings with software other than the control panel of the machine, NWADMIN, or PCONSOLE, TCP/IPv4 protocol must be supported by your network environment (IPv6 is not supported).
» Network » NetWare Network Setup Procedures
0CYL-1RH
