Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
You can store up to nine combinations of copy settings in favorite settings buttons. You can also set easy to remember names for each.
It is convenient to store frequently used combinations of settings in this way.
Even if the cascade copy printer is registered in the favorite settings, when the machine or the cascade copy printer is restarted, the registered settings are changed to the local copy settings. If you want to use the registered cascade copy printer, confirm that the power of the printer is ON → update the information for the cascade copy printer after the time has passed the [Startup Settings] setting → specify the favorite settings. (See "Cascade Copy Communication Timeout.")
The copy settings registered as [Favorite Settings] in memory are not deleted, even if you turn the main power OFF.
You can also store/edit favorite settings by pressing → [Register/Edit Favorite Settings].
You can also register favorite settings in the shortcut keys. (See "Assigning Shortcuts.")
» Copy » Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
0CYL-0K8
