2-Sided Original
You can scan each side of a two-sided document loaded in the feeder separately.
For information on the optional products required to use this function with the imageRUNNER ADVANCE 4235/4225, see "Optional Products Required for Each Function."
When you are scanning originals with a horizontal (landscape) orientation, such as LTRR, make sure to place them horizontally in the feeder. If you place these originals vertically, the back sides of these originals are scanned upside down.
Press [Scan and Send].
Specify the destination → press [Options] → [2-Sided Original].
Select the type of two-sided original → press [OK] → [Close].
[Book Type]:
The front and back sides of the original have the same top-bottom orientation.
[Calendar Type]:
The front and back sides of the original have opposite top-bottom orientations.
» Scan and Send » 2-Sided Original
0CYL-10L
