Adjusting Density Manually
You can adjust the density level to match the darkness of your original before sending a fax. You can also adjust the background density for originals such as colored paper.
Press [Fax].
Specify the destination → press [Options] → [Density].
Press or to adjust the density for the original → press [OK] → [Close].
» Fax » Sending/Receiving a Fax » Adjusting Density Manually
0CYL-0SY
