You can manually print the counter report when required.
The items printed for the report and a description of each item are indicated below.
Prints the date and time the total counter check report was printed.
Prints the model name of the imageRUNNER ADVANCE machine you are using.
Prints the serial number of the imageRUNNER ADVANCE machine you are using.
Prints the total counter type that appears on the <Check Counter> screen.
Prints the number for each total counter type.
Prints the counter type that appears on the send/fax counter confirmation screen.
[Check Send Counter] appears if the fax board or the Remote Fax Kit is not available for use.
Prints the number for each counter type.
Printing the Counter Report
Press
![](./images/book_images/pubnumbers/Tun_basic_en_US/b_in_counter.jpg)
(Counter Check) on the control panel.
Press [Print List].
Press [Yes] → [OK].
