Printing Forwarding Settings
You can print the contents of the forwarding settings that have been specified. You can manually print the Forwarding Conditions List whenever necessary.
Press [Function Settings] → [Receive/Forward] → [Common Settings].
Press [Forwarding Settings] → [Print List].
Lists can be printed only if 11" x 17", LGL, LTR, or LTRR (plain, recycled, thin, or color) is loaded in a paper source whose settings in [Other] in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration) are set to 'On'. However, if [Consider Paper Type] for [Copy] is set to 'On' in [Paper Drawer Auto Selection On/Off], you cannot print from a paper source with color paper specified. (See "Enabling Paper Drawer Auto Selection.")
4.
Press [Yes].
5.
Press [Close].
Only an administrator can output the Forwarding Conditions List. (See "Administrator Settings.")
» Settings/Registration » Function Settings » Receive/Forward » Common Settings » Printing Forwarding Settings
0CYL-0CH
