Printing Received Images with the 2 On 1 Layout
This mode enables you to print two received documents of the same paper size onto a single sheet of paper. This mode is only available under the following conditions:
You must select the same paper drawer for printing two consecutive pages of a received document.
The paper in the selected paper drawer must be large enough for two consecutive pages to be printed out.
Example:
If the LTR paper drawer is empty, but the 11" x 17" drawer is loaded, you can print two LTR documents onto a single sheet of 11" x 17" paper. On the other hand, if the 11" x 17" paper drawer is empty but the LTR drawer is loaded, you can print a reduced 11" x 17" original on LTR paper.
Press [Function Settings] → [Receive/Forward] → [Common Settings].
Press [2 on 1 Log].
4.
Press [On] → [OK].
Select [Off] if you do not want to enable 2 On 1 Log.
If you set 2 On 1 Log to 'On', documents are printed with a dotted line in the middle. If you print the document with sender information, the dotted line is not printed in the area where the sender information is located.
» Settings/Registration » Function Settings » Receive/Forward » Common Settings » Printing Received Images with the 2 On 1 Layout
0CYL-0C6
